CY7C65213A RS485 CDC Driver
SaBh_294166
25 replies posted 10 replies posted 10 questions asked
Hello. The CY7C65213A is noted to be CDC driver compatible. Using only the CDC driver, can the RS485 mode be supported or is the Cypress driver required to be loaded to enable this mode? This is not clear to us from the datasheets.
YatheeshD_36
RS-485 protocol of USB-Serial Device CY7C65213A/211A/215A is implemented in the firmware. Hence, the feature can be used/implemented using cypress driver as well as native windows/linux CDC driver.
Yatheesh
YatheeshD_36
Yatheesh
