02:46 PM
Jun 13, 2012
02:46 PM
Will the Cy3663 firmware allow me to use 2 USB ports for two memsticks plugged in at the same time?
If the firmware would need to modified, would it be difficult? Would a 2nd FAT instance be required? Would there be enough space for the redundant code (if not then what is the point of having extra ports that are essentually unusable in practice?)
