06:35 AM
Feb 23, 2010
06:35 AM
Hi any C API at host side i dont wond .net API
11:14 AM
Feb 23, 2010
11:14 AM
There's a C++ API. No C API, you'd have to wrap the C++ API with your own. Or you could talk to the driver directly with DeviceIOControl calls.
05:45 AM
Feb 24, 2010
05:45 AM
i want a c code at host side which send or receive data from usb is it possible .Cypress provide any code which in c to access the data at host side
02:44 PM
Mar 04, 2010
02:44 PM
The driver is written in C. Take Andrew's advice and read up about using DeviceIOControl. The .h files included with both APIs should give you enough clues to make it fairly easy.
