Hello.
I purchased the CYUSBS236 kit.
I'm trying to read/write my target slave device thru SPI using the tool.
Only utility provided with the tool is the configuration and also test utility.
Is there any GUI utility that I could use on Windows based to try to read/write any target device thru SPI/I2C..?
I can't find yet.
Thank you.
To read/write any SPI slave device, you need to develop a host side application.
We have an example host application (developed in Visual Studios) for Windows to do data transfers with the on-board SPI EEPROM. The example is located at: <USB-Serial installation directory>\USB-Serial SDK\examples\usbserialexample\spimaster. You need to understand the SPI timing of the Slave device and can alter the example project accordingly.
