Looking for thermal metrics (thermal resistances) on this component (CY7C65631-56LTXI) to do thermal analysis on a PCB being designed with this hub. Specifically looking for junction-to-board, junction-to-case (top), junction-to-case (bottom), and junction-to-ambient thermal resistances. These values are common to most datasheets, yet do not appear in this one: https://www.cypress.com/file/119991/download
USB Hosts Hubs Transceivers
Please refer to the thermal resistance values from the HX2LP datasheet on Page 26. Please note that both the parts are functionally the same and are the same die and the only difference is in the manufacturing process.
Sananya
Sananya
