My application is similar to the CCG3 Charge-Through Dongle, except for some key differences:
- There is only a single USB device and no hub
- There is an integrated battery
Please see the attached block diagram. This is a space and power constrained application. Which is the best CCG device to use? Is there a benefit to using the CCG3+CCG2 used in the Charge-Through Dongle design, over a dual port IC like the CCG4? Do these devices have enough customization available to control the battery charger (shown as an I2C connection in my block diagram).
Thank you
>> The Best CCG device with sequence will be: PMG1-S3, CCG6DF, CCG5/5C, CCG4, BCR+CCG3PA, CCG3+CCG2.
The easiest implement with existing example code of SDK: CCG3+CCG2, BCR+CCG3PA, CCG4, CCG5/5C, CCG6DF, PMG1-S3.
>> The benefit is example code have already and verified on CCG3+CCG2.
>> Yes. I2C customizations is allowed and available.
Lisa
Lisa
Thank you,
Can you elaborate on the reasons for "Best CCG device"? What makes CCG4 > BCR+CCG3PA > CCG3+CCG2 ?
The reason is single chip solution, there are not need any external communications (for example, I2C) for US and DS Type-C port information exchange or Sync.
