Webinar: USB-C adoption. Simple & Cost-efficient solutions | available on-demand. Watch now !
laze_4418921
25 sign-ins First solution authored 25 replies posted
when the usb cdc works not right, data transfer from pc to usb works well and data from usb to pc can not get. However, after disconnect the uart and connect again without power-off, data transfer well again.
YatheeshD_36
For no errors to be reported, the data sent from the UART to USB side should be less than or equal to the amount of data requested from the USB side.
Please try using terminals like Teraterm in Windows or Minicom in Linux to capture the data and see if you are facing the same issue.
Yatheesh
YatheeshD_36
Can you please confirm which part/device you are referring to?
Is it your custom host application or a standard application in Windows like Tera Term?
Yatheesh
YatheeshD_36
Yatheesh
