Dear,
I downloaded EZ-PD Dock Reference Design v1.1 ISO from the following website:
https://www.cypress.com/documentation/reference-designs/ez-pd-ccg4-usb-type-c-monitordock-solution
After installation, I grabbed the example "CCG4_DOCK_REV05" from the following path:
C:\Program Files (x86)\Cypress\EZ-PD CCGx Dock SDK\Firmware\projects\CCG4_DOCK_REV05
When I was compiling, I encountered the following error:
How can I solve it?
Manu
USB EZ-PD Type-C
CCG4 has dual firmware architecture where CYPD4236-40LQXI_dock is the main project and backup_fw is the backup project. You should build and use both projects together for CYPD4236.
noboot is the project same as above but without dependency of a bootloader. This is used to debug the firmware using SWD.
CY7C65219-40LQXIT_dmc_Rev05 is the firmware project for Dock Management Controller (DMC).
Please let me know your exact application. You can use CYPD4236-40LQXI_dock + backup_fw for CYPD4236.
Pranava
Hi Manu,
Can you please create the project in new workspace and try building it?
Also please do share the log present in Output tab of the PSoC Creator so that I can help you better.
Pranava
Dear Pranava,
I found that selecting workspace'CCG4_DOCK_REV05' (4 Projects) can compile successfully.
What are the functions of these 4 Projects?
If I only use CYPD4236, can I just modify it?
And in this project, remove some GPIOs and add UART?
Manu
Pranava
