- Email to a Friend
My project is based on reference project firmware CYPD3120-40LQXI_dp_dongle it partly works except the power charging.
Below is the diagram. Before Samsung is plugged in the USB-C the MOSFET switch is off so when Samsung is plugged in the USB-C the Dp-to-HDMI converter and USB hub start working. But Samsung is a power source.
I can use one of the GPIO P1.0 or P1.1 to turn on/off the MOSFET switch. I would like to turn on the MOSFET switch to charge the Samsung from the dc/dc power supply. Could you please tell me how I can send a command to Samsung to change to power sink?
Derong Yuan
- Email to a Friend
Hi Derong Yuan,
We have already shared the example code in the threadCCG3 charge through dongle firmware The attached file is for initial PR_SWAP and DR_SWAP to make sure CCG3 is target for Power source and Data device.
Lisa
- Email to a Friend
Hi Derong Yuan,
Lisa
