USB EZ-PD™ Type-C Forum Discussions
BiSu_4440881
I want programme and debug the CCG3PA with the keil.And the debug tool is J-link. But I don't find the FLM file for the CCG3PA.
RajathB_01
250 replies posted 100 replies posted 50 replies posted
CCG3PA programming/debugging is not guaranteed to succeed with Keil+Jlink. Hence we do not support that.
Rajath
RajathB_01
Rajath
Thank you. If  the only way to debugging and programming the CCG3PA is using MIniProg3+PSoC Creaor. If I can use other tools.
You are right. There is no guaranteed method from our side to make other tools work for CCG3PA. Thanks for your understanding.
Rajath
Thank you!
Buy the way I want to install EZPD_CCGx_Power_SDK_3.2 and PSoC Creator 4.2 on win7. But failed. I had try install on different 5 PC. And have tried many times. And the result is the same. The error prompt message as shown in the picture.creator.png
What is the installer you are running? Which package did you download from web (complete / setup only / ISO) ?
Rajath
Hi Rajath
I have tried all way include complete/setup only/ ISO. And the result is same. Not successful. Please help me. Thank you.
Bill
