Hi Lisa,
I replaced the MOSFET name PD_FET_DR_N_JN_FET in pd_hal_set_fet_drive() of main.c and the variable pd_pctrl_drive and pd_cctrl_drive (the consume control signal is not used in my project) of pdss_hal.c with PD_FET_DR_P_JN_FET and found the VBUS_P_CTRL 0/1 might work but the Samsung in the USB-C is still not being charged.
main.c:
pd_hal_set_fet_drive(PD_FET_DR_P_JN_FET, PD_FET_DR_P_JN_FET);
pdss_hal.c:
/* Configuration provided from solution. */
static pd_fet_dr_t pd_pctrl_drive = PD_FET_DR_P_JN_FET;
static pd_fet_dr_t pd_cctrl_drive = PD_FET_DR_P_JN_FET;
The MOSFET is not turned on before and after Samsung plugged.
before Samsung plugged in: VBUS_P_CTRL1 =4.0V, VBUS_P_CTRL0=4.2V, VBUS =0v
after Samsung plugged in: VBUS_P_CTRL1=4.2V, VBUS_P_CTRL0=4.2V,VBUS=5.2v (the power from Samsung)
The CYPD3123 is powered on all the time by a +5v dc/dc in cicruit.
Below are measured signal voltages from a purchased board with CYPD3125 as power delivery:
before Samsung plugged in: VBUS_P_CTRL1 =1.6V, VBUS_P_CTRL0=1.6V, VBUS =2.48v
after Samsung plugged in: VBUS_P_CTRL1=0V, VBUS_P_CTRL0=0V,VBUS=5.1v
Please advise.
Derong Yuan
Hi Derong,
The U6 should be load on your board.
From your configuration of gate drive is P MOS FET, the CCG3 is working correctly with your case when U6 is load. The Provider path is enabled by VBUS_P_CTRL0/1 =0, this is P MOS drive logic. But the small error on your end is the status of before Samsung plugged in, the VBUS_P_CTRL0/1 = 1.6V and VBUS = 2.48. Please kindly follow my comment to change the pull-down resistor to pull-up to make sure VBUS_P_CTRL is same value as power source side. So that the VBUS will comes to 0V at unattached status.
Lisa
Hi Derong,
Lisa
