Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
JiMr_4783496
PD contract established.
Error: GET_SILICON_ID U_VDM failed
Retrying, ignore the above error message
Flash update mode (4b4, 1) entered
Restarting the target device
Re-negotiating PD contract after switching target reset
Error: PD contract not established after RESET
Error: DLL call returned error while fetching info
Starting CCG firmware update over CC line
Could not establish PD contract.
Error: DLL call returned error while flashing
There might be some problem in modified firmware that you have programmed. So PD contract is not getting established between the programmer and the CCG3PA.
If the hardware you are using is CYPD4532 EVK,
Please refer to Question: What should be done if the CCG3PA controller is not detected in the EZ-PD Configuration Utility? in the KBA Frequently Asked Questions on CY4532 CCG3PA Kit – KBA226613
Pranava
Pranava
Pranava_YN
100 likes received 500 replies posted 250 solutions authored
Please do clarify the following,
>> Are you trying to read/ Update configuration table from CY4532 EVK or some custom board?
>> Have you programmed any modified firmware to the board before getting this error?
Pranava
Pranava
have downloaded firmware before getting this error
Pranava
Pranava
