I create a project base on CCG3 Dongle project and then I can't start debug.
someone said I need disable Bootloadable, I tried to disable it , then I get below building error
Error: cdf.M0005: CyDsFit aborted due to errors, please address all errors and rerun CyDsFit. (App=cydsfit)
Hello chengleiw_2518246,
Please use 'noboot.cydsn' project in the same project folder as the 'noboot.cydsn' is a debug-enabled version of the same firmware application, which does not depend on the bootloader. Please use PSoC Creator 3.3 for the projects to build efficiently.
Please refer CCGx_FW_UserGuide in the installation folder of the CCGx SDK for more information and the same is attached for reference.
Anil
Anil
