Is there any code of CYPD4226notebook bootloadable in the two pictures? What are the differences? What's the difference between noboot, i2cboot,dummyboot, and backupfw? If I want to make a routine change, which one should I use?
If you have installed the CCGx Host SDK, you could fine the clarify about the difference between several projects under same workspace in SDK User Guide - C:\Program Files (x86)\Cypress\EZ-PD CCGx Host SDK\CCGx\Documentation
I believe you can use either noboot or full-feature project for your test. The only difference is noboot project has no I2C-bootloader involved.
如果这些项目的功能没有不同,感谢你能回答我的问题。再次感谢您回答我的其他问题。
