Hi Infineon Friends,
I take a stock 5225 Host SDK workspace... and in the "noboot" FW, I update config.h as described in the documentation... to remove the features not needed by my application.
And I get these errors.... what am I missing?? Thank You!!
Build error: L6218E: Undefined symbol alt_mode_mngr_exit_all (referred from app.o).
Build error: L6218E: Undefined symbol reg_intel_modes (referred from alt_modes_mngr.o).
....you will need MDK ARMCC installed in C:/armcc for this to work... and reproduce the errors....
Thank You!
JB.
USB EZ-PD Type-C
Hi @35_Engineering ,
Thank you for posting in infineon community.
I noticed that you have disabled HPI configuration in noboot project, there are few other macros related to HPI that you have to disable to avoid implicit warning in the firmware.
and
you have to define APP_ALTMODE_CMD_ENABLE (1u) macros in the config.h to avoid the errors.
few placed we are checking either CCG_HPI_ENABLE or APP_ALTMODE_CMD_ENABLE macros to enable the alternate mode related function. (e.g: Refer line number 1494 in alt_modes_mngr.c file).
Please find the attached program where i disabled the HPI and defined the required Macros.
Mohamed Rahmathulla
and
Mohamed Rahmathulla
Mohamed!!!
Thank you sir!!
I will test it this evening!!! Also, may I suggest that we create some sort of white paper, or post here... so that others may learn from this work? I'm happy to do the work for you if you like...
Maybe I create a blog post on here??
JB.
Thank you for your suggestion, we will discuss internally and will post under knowledge base section if required.
Mohamed Rahmathulla
