USB EZ-PD™ Type-C Forum Discussions
Anderson_Lin
10 replies posted 10 sign-ins 5 replies posted
PFET Gate Drivers on VBUS Path
CCG3PA has two integrated PFET gate drivers to drive external
PFETs on the VBUS provider and consumer path. The
VBUS_P_CTRL gate driver has an active pull-up, and thus can
drive high, low or High-Z.
Q: How to implement High-Z in FW ?
PranavaYN
500 replies posted 250 solutions authored 50 likes received
VBUS_P_CTRL is internally pulled up to VBUS_IN_DISCHARGE. Therefore it can't be driven High-Z when VBUS_IN_DISCHARGE is connected to the input supply. This is necessary to turn VBUS provider FET on and off.
May I know the reason why you want to drive that pin to High-Z?
Pranava
PranavaYN
Pranava
