IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB EZ-PD Type-C
NiMc_4245981
New Contributor II
I'm developing a product that will use the CYPD4225 chip.  Initially I am using the CY4541 evaluation kit.  I can't find the firmware source to start from.  I have the following installed, according to Cypress Update Manager.
CY4541 EZ-PD CCG4 EVK 1.0 Rev. *A
EZ-PD CCGx Host SDK 3.3
EZ-PD Configuration Utility 1.1
PSoC Programmer 3.28.4
PSoC Creator 4.2
When I search for examples that use CCG4 in PSoC Creator, none are found.  I've searched the hard disk and the closest I've found is a firmware from the CYPD4226, which doesn't work.
C:\Program Files (x86)\Cypress\EZ-PD CCGx Host SDK\CCGx\Firmware\projects\CYPD4226-40LQXI_notebook
YiZ_31
You can find  CYPD4225-40LQXI_notebook in the CCGx SDK:
https://www.cypress.com/documentation/software-and-drivers/ez-pd-sdk-v302-ccg2-all-applications-ccg3...
The firmware version in the SDK is up to date.
Eddie
