- Email to a Friend
I'm developing a product that will use the CYPD4225 chip. Initially I am using the CY4541 evaluation kit. I can't find the firmware source to start from. I have the following installed, according to Cypress Update Manager.
CY4541 EZ-PD CCG4 EVK 1.0 Rev. *A
EZ-PD CCGx Host SDK 3.3
EZ-PD Configuration Utility 1.1
PSoC Programmer 3.28.4
PSoC Creator 4.2
When I search for examples that use CCG4 in PSoC Creator, none are found. I've searched the hard disk and the closest I've found is a firmware from the CYPD4226, which doesn't work.
C:\Program Files (x86)\Cypress\EZ-PD CCGx Host SDK\CCGx\Firmware\projects\CYPD4226-40LQXI_notebook
- Email to a Friend
You can find CYPD4225-40LQXI_notebook in the CCGx SDK:
The firmware version in the SDK is up to date.
Eddie
- Email to a Friend
Eddie
- Email to a Friend
I had some errors when I built this using PSoC 4.2
lto1.exe: fatal error: bytecode stream generated with LTO version 3.0 instead of the expected 4.1
I got rid of this error by turning off CCG_HPI_ENABLE and CCG_HPI_PD_ENABLE. I don't plan on using HPI, so I'm just leaving this here as a note in case anyone else runs into the same problem.
ERROR: No interrupt vector
I switched to the "noboot" project which does not have this error. I would like to use the bootloader eventually, so I'm still looking for a fix to this issue.
- Email to a Friend
It is recommended to compile CCGx SDK projects with ARM MDK:
The location for binaries in the toolchain is "Keil_v5\ARM\ARMCC\bin"
Eddie
- Email to a Friend
