IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB EZ-PD Type-C
xiyu_4287396
New Contributor
As the title shows, I have some simple questions.
1、what is the main role of CCG4 in CY4532?Is it the way to transfer CCG3 control?
2、If I only use CYPD3171 and peripheral circuit for charging control,How should I configure the program with which pin?
ShifangZ_26
Hi ,
1. The Main function of CCG4 of CY4532 is:
CC bootloader host for power adapter (CCG3PA);
MTK board for CMG1 board.
2. Could you please share your requirements with block diagram? And then, specified your question?
You might refer the link: CCG3PA Power Adapter/Car Charger (1C+1A) single chip solution firmware customize steps for CCG3PA firmware to getting start.
Lisa
ShifangZ_26
Hi ,
Lisa
