I want ask if these three chips support Apple's fast charge protocol.
And when two USB ports are shared, the current of one USB port exceeds 100mA, and the fast charge of the other port is exits.
CCG3PA CCG3PA-NFET IP2726
Hi @frankcc ,
Thank you for posting in infineon community.
CCG3PA and CCG3PA-NFET will support for Apple charging. please find the reference below.
CCG3PA is a single port IC. could you please elaborate about the point which you have mentioned fot 2 USB ports.
Thanks & Regards
Mohamed Rahmathulla
Hi @frankcc ,
Thanks & Regards
Mohamed Rahmathulla
