AlAh_4392861
We are looking for a solution to combine USB, HDMI and 12V power over USB Type C. We currently have a motherboard that outputs USB and HDMI which we connect to a touchscreen display. We are hoping to redesign the motherboard and the display electronics to be able to use a single USB type C cable between the motherboard and touchscreen display. The new display will use 12V power, so I'd like to send that over the same cable as well. What ICs should I use to combine the signals on the motherboard as well as demuxing at the display electronics back into USB and HDMI. Any reference designs would be greatly appreciated!
YiZ_31
You can take a look into this reference design:
https://www.cypress.com/documentation/reference-designs/ez-pd-ccg3-usb-type-c-charge-through-dongle
However, this reference design uses Type-C plug, if you need a receptacle, you'll have to add a MUX.
Eddie
YiZ_31
Eddie
