USB EZ-PD™ Type-C Forum Discussions
NaMe_2085021
Level 4
Level 4
25 replies posted 10 replies posted 10 questions asked
Hi everyone,
Could you help me?
I use CYPD3120 for my project.
I want create basic program with dynamically update sink power capability, when I press button.
My schematic in attachment.
Thank you!
Nazar Melnichek
YiZ_31
You can refer to the following example code:
void change_pdos(void)
  pd_do_t SRC_PDO[4];
    if ( //read pin status register somewhat way == false)
        SRC_PDO[0].val = 0x0001912C; //5V 3A (This value can check on xml file created by EZ-PD Configuration Utility)
        SRC_PDO[1].val = 0x0002D0D2; //9V 2.1A
        SRC_PDO[2].val = 0x0004B12C; //15V 3A
        SRC_PDO[3].val = 0x0006412C; //20V 3A
        dpm_update_src_cap(0, 4, SRC_PDO);
        dpm_update_src_cap_mask (0, 0x0F);
        dpm_pd_command (0, DPM_CMD_SRC_CAP_CHNG, NULL,NULL); //Send PD command about the changes in source capabilities
CY_ISR(GPIO_ISR_handler)
    //clear any active interrupts on corresponds pin for interrupt
    change_pdos();
Eddie
YiZ_31
  pd_do_t SRC_PDO[4];
    change_pdos();
Eddie
Thank you very much!
It`s works for me, but I have a small problem.
I got 9V, 12V and 15V, but  I could`n get 20 V.
Could you help me?
Thank you!
Nazar Melnichek
YiZ_31
Hi Nazar,
Have you checked the PD log? There are no 20V PDO in the source_cap message?
Eddie
Hi Eddie,
I checked the pd log. In the source_cap message there are 20V PDO.
This will work if you change the size of the array to 4 and remove the odes from values such as 15V.
Part my code:
  pd_do_t SNK_PDO[4];
       if ( SW1_Read() == false )
        SNK_PDO[0].val = 0x0001912C; //5V 3A (This value can check on xml file created by EZ-PD Configuration Utility)
        SNK_PDO[1].val = 0x0002D12c; //9V 3A
        SNK_PDO[2].val = 0x0003C12C; //12 3A
        SNK_PDO[3].val = 0x000640C8; //20V 2A
        dpm_update_snk_cap(0, 4, SNK_PDO);
        dpm_update_snk_cap_mask (0, 0x0F);
        dpm_pd_command (0, DPM_CMD_SNK_CAP_CHNG, NULL,NULL); //Send PD command about the changes in source capabilities
CY_ISR(SW1_Handler)
    SW1_ClearInterrupt();
    change_pdos();
int main()
    SW1_int_StartEx(SW1_Handler);
Thank you!
Nazar Melnichek
Part Code:
  pd_do_t SNK_PDO[5];
        SNK_PDO[3].val = 0x0004B12C; //15V 3A
        SNK_PDO[4].val = 0x000641F4; //20V 5A
        dpm_update_snk_cap(0, 5, SNK_PDO);
CY_ISR(SW1_Handler)
    change_pdos();
int main()
