EZ-PD devices are very varied.
As a beginner I need your advice to choose a device.
Our devices are,
/ As far as possible, we do not want to use the host CPU and would prefer stand-alone operation of the EZ-PD only.
/ Sorce only (~45W).
/ Multiplexer control required due to use of superspeed.
/ USB 2.0 High Speed also required
/ No power source protocols other than USB PD are required (no BC1.2 required either).
The ACG1F series looks good, but no corresponding product can be found.
Are there any other suitable series?
Should the series for DRP be used for Source-only?
I need your help, thank you.
Yukio Oyama
/ PPS is not required, but is acceptable with it.
/ Alternate mode not required.
Thank you for posting in infineon community.
Have you checked PMG1 Series. please check the below link
PMG1 is the series where infineon introduce PD along with microcontroller, it will meet the requirement which you are looking.
Thanks & Regards
Mohamed Rahmathulla
Thanks & Regards
Mohamed Rahmathulla
Hello Mohamed-san,
Thanks for your reply.
I am in the process of confirming it. So far, your suggestions seem good to me.
Are there any documents summarising the flexibility of user customisation?
I need GPIO control for SuperSpeed multiplexing and voltage switching of power supply IC.
I have not yet checked any tool.
Can I do that with Modus Tool Box Software and the EZ-PD Configuration Utility? What is the difference between these two tools?
Yukio Oyama
Hi Yukio Oyama-san,
1. Modus Toolbox
it is a latest IDE which infineon providing to support the development for most of controller based product and planning to have single ide for every solution which is Modus Toolbox.( Migrating old product to support is under process)
here is the user guide for ModusTool box
2. EZ-PD Configuration Utility
it is GUI based tool where you can generate the PD configuration for the PD controller, ModusTool Box has this tool internally to configure the PD devices in a easy way.
for more detail you can refer the below link
Thanks & Regards
Mohamed Rahmathulla
