Hello
With reference to KBA226613, I programmed a FW that enabled VCONN to the CY4532 and connected it to the CY4533 KIT. I added "20V/5A" to the Source PDO and it worked, but when I confirmed the CY4500 analyzer log, Src CAP is "20V/3A". Please tell me the possible cause of the event that the SRC CAP current value becomes "3A".
Best Regards
USB EZ-PD Type-C
Hello
Thak you for your answer.
I was able to resolve this issue.
Best Regrads
Thank you for posting on the Infineon community.
Can you please comment for the following,
1) Please check the OCP limit that you have set after changing the source PDO to 20V/5A.
2) Connect 24 V power supply on J2 screw terminals of the Power Board and slide the switch to DC input side.
Note: You must use an external supply instead of the DC jack ( J1) and connect it to J2 terminals else VCONN operation will not happen.
3) Does the supply used here supports 20V/5A?
4) May i know the procedure you are using to set 20V/5A PDO?
5) Please check if the Type C cable that you are using has EMCA support.
6) Ensure that the "cable discovery enable" parameter in the EZ-PD configuration is set to YES. CCG3PA will check for cable identity and will then advertise the 20V/5A PDO.
7) Please share the CC logs.
Please follow each and every step that is mentioned in the said KBA under the section " How do I add VCONN support to the EVK?"
Abhilash P
Hello
Best Regrads
