Webinar: USB-C adoption. Simple & Cost-efficient solutions | available on-demand. Watch now !
Eason_Cho
Distributor - Zenitron(GC)
50 sign-ins 25 sign-ins 10 sign-ins
I would like to read out checksum of CCG3PA by CLI command line, the read out value by CLI must same as the checksum value by PSoC Programmer.
I have typed command with CCG3PA, but checksum value is not meet PSoC programmer, PLS help me to review the CLI commands as following image and correct it.
Eason_Cho
I used following command to read out checksum value can same as PSoC programmer, thanks.
>PSoC4_CheckSum 0x8000
YiZ_31
You can refer to this document for the correct procedure of reading checksum:
https://www.cypress.com/documentation/programming-specifications/ccgx-cypdxxxx-programming-specifica...
If the two value is different, you can go to the hex and find out the checksum yourself.
Eason_Cho
