Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
YiZ_31
In the firmware I sent to you, enable UFP_ALT_MODE_SUPP marco and set UFP_MAX_SVID_SUPP to (1u). Test the firmware and let me know if the issue still exists.
Eddie
YiZ_31
Hi Jeremy,
Have you set Modal Operation supported to Yes? That could cause some of this kind of issue.
Eddie
JeGr_4019896
First like received
Hi Eddie,
I was able to make the CYPD3175 work correctly with a modified version of the FW you sent me.
I am running into a new obstacle now. If I use a USB-C cable from Apple, the alt mode functionality no longer works. It appears that with an Apple cable the Enter Mode Request never happens. Please see the images attached.
^Discover Identity between source and sink
^With Apple Cable
^Non apple cable
Jeremy
YiZ_31
Hi Jeremy,
If my understand is correct, your source device stop sending Endter Mode with an Apple Cable. May be you should take a look at your source device.
Eddie
YiZ_31
Hi Jeremy,
Eddie
Hi Eddie,
I do not have control over the source device, I can only configure the cypress chip in this setup.
I do have modal operation supported. I am wondering if this is a problem related to thunderbolt 3 not being supported by the FW of CYPD3175.
Jeremy
