Hi @Sananya_14 / @PranavaYN ,
we're using CCG3PA as Sink and Power bank source code application in our custom design.
we have a requirement to support QC 4.0, QC3, QC2 and QC legacy as a Sink.
Do we have this provision in CCG3PA ?
As we know QC is all about handling Dp Dm lines i.e., generate pulses, vary voltage ranges on Dp Dm lines, I believe we can achieve this in Power bank applications as well. Correct me otherwise.
Thanks and regards,
Pranay.
USB EZ-PD Type-C
Hi Pranay,
Current Power SDK firmware projects only support BC 1.2 and AFC as sink.
QC2 and QC3 sink are based on Dp Dm line voltages but QC4.0 protocol uses USB-PD 3.0 PPS. Since CCG3PA doesn't support PPS in sink role, this will be a difficult requirement to achieve.
Pranava
Hi Pranay,
Pranava
HI pranava,
What about QC2, QC3 ?
They doesn't need any support for PPS in Sink role. We should be able to handle those protocols in existing SDK itself.
Correct me if I'm wrong.
--Pranay.
Yes, you should be able to handle QC2 using SDK. QC3 has a continuous mode operation. We cannot confirm if it would comply with the timing requirement for that mode since we have not tested it.
Pranava
Hi Pranava,
So you mean to say that CCG3PA as Snk only, we can vary voltages on Dp Dm lines using library functions ?
I believe no need any tweak in the functions as per current Src code library.
To Source DP_SRC / VDM_SRC no HW changes also required. correct ?
Let me know your thoughts.
Pranay.
You can refer to cgdb_apply_sink_term and other corresponding functions with prefix "cgdb" in pdss_mx_hal.c file for functions corresponding to legacy charging block in CCG3PA.
As QC as sink is not currently implemented you might have to change the legacy charging state machine developed in battery_charging.c file to include it.
Pranava
To Source VDP_SRC / VDM_SRC on D+/D- lines , no HW changes would be required. correct ?
I'm asking this because, Our custom HW will not function as a SRC at any instant, it is designed to be only sink.
--Pranay
No hardware changes are required to source VDP_SRC / VDM_SRC.
Pranava
