Hi
We have a problem with the PD-negotiation on some old Lenovo laptops. The problem seems to be that after the dock have made a PR_SWAP and all is good the dock is sending a source-cap request to the laptop and the laptop doesn't ack this with GOODCRC. After som attempt the dock forces a HARDWARE reset.
So root problem is that of course that the laptop doesn't respond to the source-cap request at all, but it is a bit unclear why the dock sends a source-cap request at all after the power swap. There is no need for that at this point.
Maybe there is a setting in the CYPD4226 FW where that behaviour can be disabled?
Attached this PD-log. First instance of the problem is on line 94-100.
Cheers
Olof
Hi Pranava!
Thanks for getting back. Will send source-code separately.
Noticed another similar issue one the same type of laptops, this time the laptop misses to send GOODCRC on VDM-messages, more or less at the same point in the state-machine I believe. The VDMs in question originate from the HPD-events from the TV.
Cheers
Olof
Can you please share the Firmware project you are using for the dock? I will go through it and get back to you regarding this issue.
Pranava
Hi Pranava!
Cheers
Olof
There was an issue with the laptops wherein it stopped responding to PD messages after PR_SWAP is issued. Switching to power role Source helped resolve this.
Pranava
