Geromino
50 replies posted 25 replies posted 10 replies posted
CCG3PA Car Charger (CLA)   debug mode step by step ( step over )
we get Error: dbg.M0015   after passing
  1.   timer_start (0, LED_TIMER_ID, LED_TIMER_PERIOD, led_timer_cb)
  2. instrumentation_task();
in order understand  the flow of power sdk  in crutual  go step by step to see  sequence and call reference function ( ability look on the stack pointer )
for example  which function  (app_callback )  and when  ( time line ) call by  by PD stack
please advice ?
PranavaYN
500 replies posted 250 solutions authored 50 likes received
Sorry for the delay in response.
We were able to reproduce the issue. This is caused by Watchdog timer timeout causing the chip to reset.
In order to solve this, please do disable WATCHDOG_HARDWARE_RESET_ENABLE and RESET_ON_ERROR_ENABLE macros present in config.h file.
Regards,Pranava
Pranava
PranavaYN
The Error: dbg.M0015 mentioned is a very generic one.
Can you please provide more details on the error window that you get?
Is this issue occurring in our EVK or on a custom board?
Can you disable the deepsleep mode in the project and try debugging?
Please do make sure debugging setting is as per the Debugging CCG3PA with a MiniProg3/Miniprog4 - KBA227291.
Pranava
Pranava
t haapens on cy4532 evk board  when pass instrumentation_task(); function either when
also SYS_DEEPSLEEP_ENABLE  0 or 1
all setup  done  according
PranavaYN
We are not able to reproduce this issue with the project you shared in another thread.
Are you using "noboot" project for debugging? Also does this occur every time you try debugging?
Pranava
Every time
Please compile CLA sdk example noboot project on cy4532 evk and go step by step F10
When you pass instrument task the debug failed
PranavaYN
Regards,Pranava
Pranava
