PMG1-S3 H/W guide line for DRP EPR(140W)
Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
NoAr_1540581
Distributor - Macnica (Japan)
5 solutions authored 250 sign-ins 100 replies posted
Hello
Are there any reference document for hardware design guidelines when creating an EPR (140W compatible) and DRP (Dual Role Power) board using the PMG1-S3? Since it is compatible with 140W, I would like to confirm if there are any notes on heat generation including the layout.
Also, I am  aware that there are already PMG1 hardware guidelines below.
※AN232565 EZ-PD™ PMG1 MCU hardware design guidelines and checklist.
Best Regards
Neo_Qin
5 likes given 250 replies posted 250 sign-ins
Hi @NoAr_1540581 ,
So far, we only have PMG1-S3 kit with 140W sink operation and its thermal data is available with the KIT docs. Since the forum is a public domain, some technical information cannot be posted here without authorization. If you need it, it is recommended to submit an application through the Infineon case management portal.
For DRP EPR we have the hardware design in progress as per the schematics available in application note AN232565. According to the current schedule, relevant data will be released in 2023/Q2.
Neo
Neo_Qin
Hi @NoAr_1540581 ,
I think you can take "AN235644_USB PD DRP (dual-role power) schematics using EZ-PD™ PMG1 MCUs " as reference, you can download it from following URL:
https://www.infineon.com/cms/en/product/universal-serial-bus/usb-c-high-voltage-microcontrollers/ez-...
The CY7113 EZ-PD™ PMG1-S3 prototyping kit also released in Infineon portal:
https://www.infineon.com/cms/en/product/evaluation-boards/cy7113/
Neo
NoAr_1540581
Hello
Yes, I  am understanding that we can take schematic for DRP, but Is there a HW design guide that considers pattern layout and heat generation when designing "EPR(140W" with PMG1-S3?
Neo_Qin
Hi @NoAr_1540581 ,
Since PMG1 is relatively new product, I will contact it internally and get back to you soon.
Neo
Neo_Qin
Hi @NoAr_1540581 ,
Neo
