Is there a sample project/source code example for a USB-C PD source application? Currently, it seems ModusToolBox only have a sink example. If a source project is not available yet, do you have a target date of release?
Jonathan
USB EZ-PD Type-C
Hello JoLu,
Thank you for posting on Infineon Community.
As you well noted, we currently do not have a PD source code example available for PMG1 devices.
However, we are currently working on it.
It is scheduled for release in Work Week 50 (mid-December).
I appreciate your patience on this.
Pablo
Hello JoLu,
Pablo
Hi Pablo,
Thanks for your reply. We have experience working with the CCG3PA chipset and wrote firmware based on the CCG3PA power adapter (source) code example in the past.
We know the functions are different for PMG1, but is it possible to write our own PD source code for PMG1-S1 or does it involve too many low-level (perhaps hidden) function calls where it's not likely that we can get something running before the example code is available in December?
Jonathan
Hello Jolu,
In order to support the source functionality, the PD Stack middleware should support either a DRP or a Source library.
The current PD Stack available in GitHub has only sink libraries.
Therefore, developing the source functionality will need to be done from scratch, and will very likely take longer than waiting until December.
I apologize for the inconvenience.
Pablo
