USB EZ-PD™ Type-C
Geromino
Contributor II
what means for ?
Sananya_14
It is used to remove the internal resistive divider on the FB pin.
uVDM stands for Unstructured Vendor Defined Message which is used to send any custom message as per requirement. Please refer to section 6.4.4 of the USB PD Spec for more details.
Sananya
Sananya_14
It refers to USB PD Sub-System in our devices.
Sananya
Geromino
Contributor II
please elaborate  this line  i didnt find  any explanation
PDSS->ea_ctrl |= PDSS_EA_CTRL_RES_DIV_BYPASS;
UVDM ->what means for ?
Sananya_14
Sananya
