On Client side of CCG1 kit I am unable to read device detail from EZPD Configuration tool, after connection if i read device below error is seen.
Configuration read over I2C interface succeeded
Error: Configuration table signature is not valid
Let me know,Do i need to flash the firmware. Where can i find default firmware for CCG1 kit or I can we use default configuration table and restore data back. Pl let me know the procedure so that, I can able to read back the device detail about PDO...SVID.. on client side.
Tool shows below info on client side.
CYPD1121-40LQX1
Monitor
Firmware Base: 1.0.0.329
APP:0.1
Thank you,
Hi All,
Found that to work with Client side i need to use 1.1 version and for Host side we need to 0.98 version. Looks there is some bug within framework. To be looked further from core team.
Hi Arun,
We are checking the EZ-PD configure Utility, please kindly wait for a moments. Thank you in advance.
Lisa
