Could someone point me in the direction/documentation/example projects of implementing a custom alt mode, particularly in how the DFP initiates entering the mode, preferably automatically after the PD contract finishes negotiating. Taking a look at the "cy_alt_mode" gave me some clues as to the implementation requirements, but beyond defining the SVID, adding it to the al_modes_config.h along with callbacks, and editing the config.c (via the EZ-PD Config Utility)... what more needs implementing?
The UFP is based of the Power Bank project and the DFP is based off the Adapter project, if that matters.
Thanks kindly,
Nathan
- alternate mode
- ccg3pa
Hi Nathan,
If you could like to implements UFP_D on CCG3PA, below process for your reference.
1. Install latest power SDK.
https://www.cypress.com/documentation/software-and-drivers/ez-pd-ccgx-power-software-development-kit
2. New fill a project based on CYPD3171-24LQXQ_pb example project. Select CYPD3171-24LQXQ_pb example project. And select finish.
3. Disable Type-C and Type-A hardware relates code.
Disable codes:
power_bank.c - (line 49, col 1):
power_bank.c - (line 64, col 1):
power_bank.c - (line 153, col 1) :
power_bank.c - (line 164, col 18): return 4500;
power_bank.c - (line 291, col 1):
main.c - (line 586, col 1):
alt_modes_mngr.h - (line 519, col 7):
stack_params.h - (line 72, col 72): #define CCG_TYPE_A_PORT_ENABLE (0u)
config.h - (line 55, col 57): #define POWER_BANK (0u)
config.h - (line 94, col 81): #define REGULATOR_REQUIRE_STABLE_ON_TIME (0u)
config.h - (line 387, col 58): #define CCG_CABLE_COMP_ENABLE (0u)
config.h - (line 399, col 59): #define BATTERY_CHARGING_ENABLE (0u)
config.h - (line 462, col 61): #define VBUS_OVP_ENABLE (0u)
config.h - (line 477, col 61): #define VBUS_UVP_ENABLE (0u)
config.h - (line 498, col 63): #define VBUS_OCP_ENABLE (0u)
config.h - (line 518, col 64): #define VBUS_SCP_ENABLE (0u)
config.h - (line 578, col 60): #define UFP_ALT_MODE_SUPP (1u)
4. Update the files under alt_mode folder. CCG3PA SDK just added 04B4 as SVID for CC bootloadering at initial stage of CCG3PA CC programming.
alt_modes_mngr.c - (line 116, col 1): // static uint8_t get_base_alt_mode_svid_idx(uint16_t svid);
alt_modes_mngr.c - (line 1178, col 1): // if (get_base_alt_mode_svid_idx(svid) != MODE_NOT_SUPPORTED)
alt_modes_mngr.c - (line 1316, col 1): // static uint8_t get_base_alt_mode_svid_idx(uint16_t svid)
alt_modes_mngr.c - (line 1319, col 1): // uint8_t idx, base_am_numb;
alt_modes_mngr.c - (line 1325, col 1): // base_am_numb = sizeof(reg_alt_mode)/sizeof(reg_am_t);
alt_modes_mngr.c - (line 1327, col 1): // for (idx = 0; idx < base_am_numb; idx++)
alt_mode\alt_modes_mngr.c - (line 1336, col 1): // if (reg_alt_mode[idx].svid == svid)
alt_modes_mngr.c - (line 1361, col 7): #if 1 // ICL_CONFIG_DISABLE
alt_modes_mngr.c - (line 1726, col 1): //
\alt_modes_mngr.c - (line 1740, col 1): // svid_idx = get_base_alt_mode_svid_idx(svid);
alt_modes_mngr.c - (line 1772, col 27): #if 1 // ICL_CONFIG_DISABLE
alt_modes_mngr.c - (line 1925, col 1):
alt_modes_mngr.c - (line 2135, col 6): #if 1//ICL_CONFIG_DISABLE
5. Add a cypins and named with HPD into the CYPD3171xxx.cydwr and it should be assigned to pin#5 of CYPD3171. (Refer below figures.)
6. Add a hard code for DisplayPort Alt Mode pin assignment supported.
#if (PB_CONFIG_TBL !=1)
/* Get DP Pin configuration supported from config table. */
dp_config = get_pd_port_config(port)->dp_config_supported;
#else
/* Hard code for DP configure support, support CDEF. */
dp_config = 0x3C;
#endif
7. Open Ez-PD configuration Utility and select power bank application. And change below items step by step.
8. Replace the config.c file in the example project with the file from EZ-PD Configuration Utility.
Lisa
Hi Nathan,
Disable codes:
#else
dp_config = 0x3C;
#endif
Lisa
