USB EZ-PD™ Type-C Forum Discussions
NiMc_4245981
10 replies posted 10 questions asked 5 replies posted
I'm trying to decide if I can update our CCG3 device through the exposed Type-C port.  Will external hardware be required, or can I connect directly to a PC with a C-to-C cable?
YiZ_31
External hardware is needed for CC bootloader. Directly connected to a PC will not work. Take CY4532 for example, a USB-Serial Chip and CCG4 is needed to update CCG3PA. CCG3 need similar external hardware to update through CC.
Eddie
YiZ_31
Eddie
YiZ_31
To make some supplement, CCG3 integrates a complete full speed USB 2.0 device controller which can be used to update firmware. So if your CCG3 use USB bootloader then it can be update through Type-C port without external hardware. So the answer to your question maybe yes if you use USB bootloader.
Eddie
