USB EZ-PD™ Type-C Forum Discussions
jaxi_4346491
Dear Sir/Madam,
I tried to use a USB to I2C dongle to connect my PC with CY4533 BCR with slave address of 0x08. The I2C bitrate of the master is 100kHz.But I failed to connect. It looked that the clock was holden low for several pulses by the CY4533 before a narrow ack signal from CY4533. Finally the master failed to connect the CY4533. Can you please advice what happened and how I can connect to the CY4533 BCR. If you need more information, I will paste some waveforms tomorrow. Thanks in advance.
BR/
James
YiZ_31
Hi James,
I use Miniprog 3 to connect PC with BCR and can successfully read and write register. See my waveform below. Since CY4533 is a non-programable device, your USB to I2C dongle may be responsible for this.
Eddie
jaxi_4346491
I attach the waveforms. Please kindly help. Thanks.
The first part
The second part
BR/
James
YiZ_31
Hi James,
Eddie
Thanks a lot Eddie. Can you please advice the software you use with Miniprog 3 for the I2C communication? Can you please kindly provide the link?
BR/
James
YiZ_31
Hi James,
If you have installed PSoC Prgrammer, then you can find Bridge Control Panel in its folder.
Eddie
Thanks a lot, Eddie!
BR/
James
Dear Eddie,
Now I am able to  access to the registers now. However, I cannot understanding the meaning of resitters. Can you please kindly share the register information? My email address is: rjxie@live.com. Thanks a lot.
BR/
James
YiZ_31
Hi James,
BCR HPI Spec can only be discovered under NDA now. You should talk to a local FAE to sign an NDA in order to get the doucument.
Eddie
