We implement PPS sink on CCG5,follow by Solved: PPS Request for specific Voltage - Infineon Developer Community
1.The function hpi_set_userdef_write_handler (hpi_user_reg_handler) does not work.hpi_user_reg_handler call back function can not be triggered.
2.we don't find APP_PPS_SINK_SUPPORT macro
Hello Venus,
You are correct that CCG5 in SDK3.4 is not implemented PPS SINK. SDK3.6 will cover PPS in Host design.
Lisa
Hello ,
The thread you referred to is for CCG3PA CCGx Power SDK only. It is not suit for CCGx Host SDK.
Lisa
Dear Lisa ,
As sink to use a PPS source for fast charging,does CCG5 CYPD5225-96BZXI support this feature?
If support ,what can we do to implemment this function? Any reference code ?
BR
Venus
Hello Venus,
Lisa
