Dear,
1. How to send VDM Discovery Identity request command?
I use dpm_pd_command() to send a VDM_CMD_DSC_IDENTITY Request to port1, but I don't see a message sent from the CC analyzer.
2. How to capture device VDM Discovery ack information of port partner?
For device VDM Discovery ack information, please refer to the figure below.
Manu Lin
Please refer to Section 6.3.7.3 in Power SDK User Guide to send DISCOVER_ID VDM.
Pranava
Pranava
Dear Pranava,
Thank you, using this method solved my problem.
But I have another question:
I want to copy the Discovery ID message read by Port 1 to Port 0.
What should I do to modify the Discovery ID information of Port 0?
Manu Lin
Hi Manu,
I did not understand your question completely. You want to send DISCOVER_ID message from Port 1 and receive response from port partner, then treat the response as if it was received by Port 0. Please provide the clarification regarding the same so that I can help better.
Pranava
Dear Pranava,
I found a place from pd_command_cb() to grab the Discovery ID message from port parnet.
This issue has been resolved.
Thank you very much for your assistance.
Manu Lin
