How to enable FRS using Dock SDK??
Hi, Lisa,
I enable below setting and trigger it by rising plus.
but i didn't see any CC packet sending.
#define CCG_FRS_TX_ENABLE (1u)
#define APP_FRS_TX_GPIO_PORT_PIN_P1 GPIO_PORT_2_PIN_5 // Pin#20
BR
Ivan
Hi Ivan,
1. The marco define in the SDK should be enabled.
* Enable PD spec Rev 3 support
#define CCG_PD_REV3_ENABLE (1u)
#define CCG_FRS_RX_ENABLE (0u)
#define CCG_FRS_TX_ENABLE (0u)
>> The TX and RX should be enabled as per your requirements.
2. And you also need make a rising plus with Pin#20 if you are designing a FRS TX.
Lisa
Hi, Lisa,
BR
Ivan
it can send out FRS packet now. thanks.
