USB EZ-PD™ Type-C
Hi
Use EZ-PD Configuration Utility to check the configuration file efficiency is too low during mass production. I want to develop a software to check it automatically, but I didn't find the API documents. Please help me, thanks!
Jason
ShifangZ_26
Hi Jason,
If you are looking for the manufactory test suit for EMCA, you need contact local FAE to support you. Cypress have MTK script which can work with CY4501 to verify the firmware inside of EMCA and show PASS or Fail with LED. Kindly contact local FAE if you need one. All of distributor can be find out from link:
Cypress Franchised Distributors
Lisa
Hi Jason,
Please clarify which product you are referring to and design application.
What do you mean by "check the configuration file efficiency"? Do you mean Firmware/Configuration update?
Anil
Hi Anil ,
Thank you so much for your reply!
->Our product are USB Type-C EMCA cables, use CCG1, CCG2, CCG3PA chip.
->YES
Jason
ShifangZ_26
Hi Jason,
Lisa
