USB EZ-PD Type-C
JiMr_4783496
New Contributor
how to configure different CCG3PA device address if master control multi-devices over I2C communication,, and hope to provide the detailed documents and specified  sample code related to  the aspects issues, it is not very clear as below snap picture, according to the document, seem the device register address is not configurable  due to only three fixed model, thank you!
PranavaYN
Host Processor Interface (HPI) is not supported in CCG3PA designs. Please refer to CCG3 projects from https://www.cypress.com/documentation/software-and-drivers/ez-pd-host-software-development-kit  for example implementation of HPI.
If you are looking for I2C(SCB) slave address setting in CCG3PA projects, please refer to I2C Component datasheet available in Component Catalog in PSoC Creator.
Pranava
Pranava
PranavaYN
Pranava
Pranava
