- Email to a Friend
I have questions about Configuration Parameters:
Can you please explain those Parameters in detail
1) "Dead battery" event mask
this Parameter is only useful for "dead battery" condition ? and how to use this Parameter ?
2) Rp supported and Current level
what diffetent between "Rp supported" and "Current level" ?
Both of two Parameters seems the same for setting Rp level.
3). AMD platform type - Renoir, Rembrandt_A0, Rembrandt_B0
How to know platform is Rembrandt A0 or B0?
4). For Rembrandt platform, the FW uses the one I2C Master (SCB) to inteface RETIMER and SOC, right?
USB EZ-PD Type-C
- Email to a Friend
Hello ,
1. For the dead-battery, this is event is flag of CCGx boot from dead battery case. The application could use this flag to identify the difference boot case.
2. rp_supported is presenting the Rp value of CC when CCGx is working as power source. current_level is presenting power sink capabilities. and change over current based on this value at Type-C state machine.
3. Rembrandt_A0, Rembrandt_B0 is identified by AMD, AMD will notify end customer which silicon version was shipped to end customer.
4. Yes.
Lisa
2.
