USB EZ-PD™ Type-C Forum Discussions
Ivan_Lee
5 likes given 100 sign-ins First like received
Because the ram is not enough, I try to disable UCSI interface.
After modify config.h - CCG_UCSI_ENABLE define to '0' , the compiler has some error.
Please help me to fix issue.
ShifangZ_26
10 likes given 250 sign-ins 1000 replies posted
Hi Ivan,
Since you need remove UCSI from the project, you should replace the lib of the project you are working on. By default, the lib is
pastedImage_1.png.
You could change to those:
Lisa
ShifangZ_26
Hi Ivan,
pastedImage_1.png.
Lisa
