Hello
Regarding the Quick Panel of Modus Tool Box of PMG1,
i am understanding that various parameters (PDO, etc.) can be changed using EZ-PD Configurator.
However, it is necessary to build to generate a HEX file that reflects the changed parameters.
Q)
In the development of PMG1, if the user wants to change only various configurations without buld operation,
is there a way to generate a HEX file without building for PMG1?
Best Regards
Arai
USB EZ-PD Type-C
Hi Arai-san,
Unfortunately, there is no other way than to build the program after changing the configuration. You cant directly modify the hex, which is the case in CCGx devices.
Pranava
Hi Arai-san,
Pranava
Hello Pranava san
I understand the current situation. Will it be possible to make changes without building in the near future? From the user's point of view, it is not user-friendly to have to build.
Best Regards
Arai
Hi Arai-san,
I will communicate it internally to the team. Thank you for your feedback!
Pranava
