USB EZ-PD™ Type-C Forum Discussions
NoAr_1540581
250 sign-ins 100 replies posted 100 sign-ins
We are develping CYPD3177-24LQXQ in a design and because there is no footprint recommendation in the datasheet
Could you please share the document for recommended footprint.
Abhilash_P
25 likes received 250 replies posted 250 sign-ins
  Please find attached the footprint file.
Abhilash P
Abhilash_P
Abhilash P
Hello Abhilash san
Thank you for your answer.Since the format of the file you shared cannot be opened in the customer's environment due to the tool, is it possible to share the data in the following format?
Intermediate data such as Step / dwg / dxf (footprint shape data)
Best Regards
Abhilash_P
    The attached .dra file can be opened in Allegro PCB viewer. You can download the software from the below link,
https://www.cadence.com/ko_KR/home/tools/pcb-design-and-analysis/allegro-downloads-start.html#
Please let me know if you were able to access the file.
Abhilash P
Hello   Abhilash san
Thank you for your response. I was able to confirm that the file can be opened with Allegro.
Since the using software that can be viewed is determined by the rules of their company.
Therefore, I would like to know whether it is possible to provide  dwg / dxf  file, or not.
Best Regards
Abhilash_P
   Currently we have only the .dra file.
Abhilash P
