USB EZ-PD™ Type-C Forum Discussions
chch_3621411
Level 4
Level 4
First like given
hello i have CYPD3171 board i bought mini prog3 last week and i connected it to the pc in the PSOC3 when i read from device it can detect the device CYPD3171 but in EZ-PD CONFIGURATION UTILITY it doesn't detect any device.
ShifangZ_26
10 likes given 250 sign-ins 1000 replies posted
Hi ,
EZ-PD CONFIGURATION UTILITY only can detect CCG3PA device via CC (Type-C port). Please kindly make sure CCG3PA on your end is connecting like below:
Lisa
ShifangZ_26
Hi ,
Lisa
that mean EZ-PD configuration Utility doesn't work with miniprog3 ?
can it work with miniprog4 ?
Hi ,
EZ-PD configuration Utility doesn't work with either miniprog3 or miniprog4 .  It is difference programming way. Either miniprog3 or miniprog4 is supporting SWD programming. EZ-PD configuration Utility is supporting CC bootloadering on CCG3PA device.
Lisa
sorry for long delay, so what proprammer does support EZ-PD configurations utility ??
in pictures it seems like it is the developements kit can it be used for production programming ?
Hi ,
You are correct. The KIT is CCG3PA -- Power board.
Lisa
