USB EZ-PD Type-C
qinlifeng77
New Contributor
Hi, all:
             We purchased CYUSBS234 EVK (On-board USB to I2C bridge chip CY7C65211), and downloaded the firmware of CYPD4226-40LQXI chip through this bridge chip and EZ-PD Configuration Utility software. But now the software still can't find the chip, and ‘No HID/USB-Serial Bridge devices’ have not been found.
        The mode for CYUSBS234 EVK has been set to I2C, and has tested pass with USBSerialTestUtility. Figure 1 below is the test environment, Figure 2 is the EZ-PD Configuration Utility software phenomenon.
        Is there anything else to configure or check?
Best Regards!
Lifeng Qin
PranavaYN
Based on your comments I understand that you were able to program the device and now you are not able to it again. Is my understanding correct?
If yes, do let me know if you made any modifications to the existing CYPD4226-40LQXI project?
Also please make sure that I2C_SDA, I2C_SCL, I2C_INT_EC and GND pins are connected appropriately. Also make sure that the Board is powered.
Pranava
