EZ-PD Configuration Utility I2C bridge
Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
dapec_2892156
First like given
I'm trying to program a CCG4 based chip using the EZ-PD Configuration Utility. Which devices are supported as the bridge in this application?
So far I've only been able to use a CY7C65215 chip to work with the "EZ-PD Configuration Utility". I've tried using several versions of a PSoC from a development board setup as a bridge without success, I've also tried using an Aardvark from TotalPhase without success.
ShifangZ_26
10 likes given 250 sign-ins 1000 replies posted
Hi ,
You are correct. This is only support by Cypress USB to Serial chips, CY7C6521x (CY7C65215,CY7C65210,CY7C65211, CY7C65219).
Lisa
ShifangZ_26
Hi ,
Lisa
