USB EZ-PD™ Type-C Forum Discussions
PaRi_1293246
50 sign-ins 10 questions asked 25 sign-ins
I'm using the CYPD3125-40LQXI_notebook project from the EZ-PD CCGx Host SDK as a starting point to implement an USB-C port on our new ultrasound scanner.
I have started to modify the configuration table but I don't understand some parameters.  Is there is a document that describe all the parameters that are in the configuration table?
Thank you
Patrice
ShifangZ_26
Moderator 1000 replies posted 750 replies posted 500 solutions authored
Hello Patrice,
If you have installed EZ-PD CCGx Host SDK, you could get firmware guidance on User Guide (Folder path: C:\Program Files (x86)\Cypress\EZ-PD CCGx Host SDK\CCGx\Documentation )
Screen shot of User Guide for your reference.
If your concerns is specified for configuration of Ez-PD configuration Utility, please feel free to refer user manual under Ez-PD configuration Utility (folder path: C:\Program Files (x86)\Cypress\EZ-PD Configuration Utility\Documentation )
Lisa
ShifangZ_26
Hello Patrice,
Lisa
