USB EZ-PD™ Type-C Forum Discussions
WillH
10 replies posted 10 sign-ins 5 replies posted
Dear Staff,
How to enable FRS functionality using EZ-PD Config Utility?
Thx,
WH
Abhilash_P
25 likes received 250 replies posted 250 sign-ins
    Please refer to the following image on how to enable FRS using EZ-PD Config utility.
The Type C controller used here to show the FRS feature is CCG3.
Abhilash P
WillH
Test
Abhilash_P
Abhilash P
WillH
Hi Abhilash,
But how come mine shows "None" and grayed out? I am configuring CYPD3171-24LQXQ.
Abhilash_P
   Please use the drop down option to select FRS receive and transmit options.
Abhilash P
WillH
Can you explain to me the meaning of  "Flashing mode index = 1"? If I want to program the device thru the CC interface, any modification needs to be made?
Thx,
Will
WillH
Also, if Rp supported sets to Default, what is the current limit?
WillH
Sorry, few more terms wanted to clarify:
What are the definitions of "Is source extremally powered" and "is sink extremally powered"?
Thank you a lot
Abhilash_P
    A device can be powered from 2 sources, it can be either bus powered or externally powered through wall power source.
Abhilash P
Abhilash_P
   Please refer to the following table,
Rp Rd Vbus current limit
56 kΩ 5.1 kΩ 500 or 900 mA
22 kΩ 5.1 kΩ 1.5A @ 5V
10 kΩ 5.1 kΩ 3A @ 5V
For Default refer to  the first row.
Abhilash P
WillH
Dear Cypress,
What is the difference between Reject and Not_SUPPORTED under DR_Swap response pull down menu?
WillH
Thank you a lot Abhilash P ^^,
Thx,
Will
WillH
Hi Abhilash P,
What's the meaning of "Config table major version = 2"? Is this # always fixed?
Thx,
Will
WillH
Hi Abhilash P,
Under what consideration do I need to set "Sink USB suspend = Yes"? What does it mean?
Will ^^
Abhilash_P
Hi Will,
   Please refer to the following images to get a clarity on USB suspend option,
Abhilash P
WillH
Hi Abhilash,
Cleared. Is above info from USB-IF spec?
Also, what is the difference between Reject and Not_SUPPORTED under DR_Swap response pull down menu?
WH
WillH
Also, what are the definitions of Wait, Reject and Not_SUPPORTED under DR/PR_Swap response, respectively, under pull down menu? An appropriate documentation is appreciated ^^
Abhilash_P
  Please refer to section 6.3 in USB PD Spec to know more about accept, reject and not supported options.
Abhilash P
WillH
Hello Abhilash,
Do you have detailed explanation about SCEDB parameters. I don't see them in EZ-PD Configuration Utility User Manual?
Thx ^^,
WillH
EZ-PD Configuration Utility User Manual P. 28 ^^
Abhilash_P
Please find the description in the attached image,
Abhilash P
WillH
Dear Cypress,
What is the purpose of having below User Parameters?
Abhilash_P
   The shot is not clear. Can you please provide a more clear image or you can just mention which parameter you are referring to.
Abhilash P
